Turn software update?
Re: Turn software update?
Postby markcadcam » Mon Apr 17, 2023 12:57 pm
Nevermind, I got it.
markcadcam
Postby cncdrive » Mon Apr 17, 2023 1:13 pm
Thread cutting with spindle syncronous motion using spindle encoder feedback. (G76)
Postby CNC Doktor » Mon Apr 17, 2023 8:35 pm
Nice videos.
I can't wait.
I have Boxford 125 TCL that needs retrofitting.
Will it be possible to use servo as headstock spindle and use encoder outputs from servo drivers as feedback?
CNC Doktor
Postby cncdrive » Wed Apr 19, 2023 9:25 am
Here is another video manufacturing the chess figure with G95 and Gg96 both turned on.
This is interesting, because G95 is spindle controlled feedrate mode and G96 is constant surface speed.
The 2 modes depends on eachother.
The UCCNC controls these modes using the spindle encoder in close to realtime.
You can hear as the spindle speed turns up when the knife goes closer and closer to the centerline.
The spindle speed limit is set to 2000 RPM on this video, it could rotate up to 2500 RPM, but we limited it to 2000 RPM in the G96 setting.
https://cncdrive.com/video/Chess.mp4
Postby asuratman » Wed Apr 19, 2023 12:22 pm
do you use servo motor or ac motor with additional encoder on this lathe ?
asuratman
Postby A_Camera » Wed Apr 19, 2023 1:12 pm
It will be very interesting to test the new release. Personally, I am excited to see the benefits of using a real lathe control. I don't know what difference it will make for me, I can only run my spindle at maximum 1000rpm now, but I guess it will result in some improvements. Currently I have to adjust the rpm manually or in the G-code, which works also, but automatic adjustments would be better. Anyway, threading works well also with the traditional UCCNC and manual G-code, as I do here in this video:
https://youtu.be/P0-3K8x2U9M?t=756
Here I do threading in a very careful way, since that tool post is a bit weak, but in the meantime I installed a new one, a Multifix type, which is miles better so I can do more aggressive cuts even in steel.
A_Camera
Postby asuratman » Thu Apr 20, 2023 3:59 pm
sorry, no problem, i found the answer on the spindle used ...
asuratman
Postby nhcnc » Fri Apr 21, 2023 4:27 pm
Super excited for this.
nhcnc
Postby needleworks » Fri May 26, 2023 7:56 am
Are we any closer to a release date :D
needleworks
Postby cncdrive » Sat May 27, 2023 9:15 pm
2 minor bug fixes left and we have to finish adding the new settings to the old "Default" screenset and then we will be ready to release.
