Calibrating axes.
Calibrating axes.
Postby SteinarJohansen » Sat Oct 08, 2022 6:25 pm
Hi, first of all i'm new to this forum and to UCCNC. Have been using Arduino but upgrading.Waiting for my AXBBE controller and looking at the software to UCCNC. Software setting is steps pr unit? How much is a unit? Is it metric?
I have steppemotor Nema 23 with 1.8 degree steps and run with 3200 steps pr. rev. The screw is pitch 5 mm. I need to know "steps per unit". What is 1 unit?
SteinarJohansen
Re: Calibrating axes.
Postby appiuccnc » Sat Oct 08, 2022 11:33 pm
SteinarJohansen wrote:Hi, first of all i'm new to this forum and to UCCNC. Have been using Arduino but upgrading.Waiting for my AXBBE controller and looking at the software to UCCNC. Software setting is steps pr unit? How much is a unit? Is it metric?
Hello Steinar
As a new(ish) user I'll try to help.
UCCNC is very easy to setup - with a little learning curve behind you. You don't really need to calculate steps, pitch...... as when you run a calibration UCCNC askes you have far you want to move in units and you measure the movement and input that movement number. the number ( units )is either mm OR inches, I'm using mm's but I think it is the same in inches, if you tell it to move 10 ( inches ) and it moves 1/2 an inch you input .5.
UCCNC works out all the mechanical variable for you, I recently calibrated a 4th ( rotary ) axis and was dreading doing it, using a digital level, it couldn't have been easier. same for the linear axes I have done.
Years ago I was using Mach 2 then 3, I don't know if Mach4 is any better but back then setting an axis was a tedious process, UCCNC isn't hard or tedious.
Best regards
Ed
appiuccnc
Postby ger21 » Sun Oct 09, 2022 2:02 pm
SteinarJohansen wrote: How much is a unit? Is it metric?
UCCNC works in whatever units you want. If you do your CAD/CAM in mm's, and your g-code is in mm's, then steps/unit is steps/mm.
It's basically whatever units your g-code uses.
Postby wmgeorge » Sun Feb 05, 2023 3:07 pm
This is the only motion control program that I have used that does not have a Metric or Imperial setup choice, including my lasers, why? All my old Mach3/4 files are in Inches, so when I would try to run in UCCNC they all need to be converted to MM? Or do I use a G20 to make sure the controller knows these are Inch files not Metric. Units of MM are much different than Units of Inches.
Ready to dump Mach4 because of the Homing and Limit issues I am having but I am not prepared to lose all my old work.
wmgeorge
Postby ger21 » Sun Feb 05, 2023 7:26 pm
Just setup two profiles, one for metric, and one for inches.
Postby wmgeorge » Mon Feb 06, 2023 10:16 pm
So to change over to Inches just use the Calibrate to equal One Inch and then Save as a Inches Profile? Never used Calibrate before.
wmgeorge
Postby Delco » Tue Feb 07, 2023 1:38 am
wmgeorge wrote:This is the only motion control program that I have used that does not have a Metric or Imperial setup choice, including my lasers, why? All my old Mach3/4 files are in Inches, so when I would try to run in UCCNC they all need to be converted to MM? Or do I use a G20 to make sure the controller knows these are Inch files not Metric. Units of MM are much different than Units of Inches.
To be honest it is not good practice to use code generated for a different system on your current system , easy to regenerate with the proper UCCNC post processsor.
Delco
Postby wmgeorge » Tue Feb 07, 2023 2:16 pm
Yes your right, instead of messing around with the Inches conversion I will do as you suggested, thanks again! :)
wmgeorge
Users browsing this forum: Bing [Bot] and 32 guests
