Hello Group
My cnc router was working well when I started to work on squaring it up.
I have a X with a slaved A xis, a Y Axis and a Z axis.
The X ( and A ) and the Z work with no problem, the Y axis when commanded to move - through a CncDrive MPG, causes the motor to " bump " ( like it move one step only ) then stops, the screen/s continue to show the axis coordinates moving though.
The power to the whole system then needs to be cycled to repeat the problem.
I am running NEMA34 closed loop steppers and have replaced both the Y axis controller and stepper, with the same fault for all hardware configurations.
I have ordered a new AXBB-E controller.
All the wiring is well connected, the connectors are well seated in their sockets.
Has anyone had a problem like this before and if so, was it the AXBB-E??
Ed
