Hello Everyone,
I've encountered an issue with my AXBB-E controller and my VFD (FULING DZB280 3.7kw)/Spindle (3.2kw 24000RPM @ 400hz) setup. The entire system is powered by two independent power supplies. The first is 24 volt/5 amp which powers both the VFD as well as the AXBB-E controller. The second is 5 volt/2 amp which is only connected to the 5 volt input on the controller.
As the title states, I am unable to get the controller to output it's full 10 volt analog signal when it is connected to the VFD. I also tested the controller with the 5v jumper enabled and it is unable to output the expected 5 volt analog signal. Not only this, but the output voltage is not stable when the controller and VFD are connected. When measured with a multi-meter, I see 4.78-4.80 volts when the VFD is hooked up and running, less than half of the expected voltage. With the VFD is disconnected from the controller I am able to measure a stable, full 10 volts. This is also noticeable when I try to target 340HZ on the VFD. It will get to that frequency but then proceed to waver between 338HZ and the desired 340HZ.
The big question is what could cause this? Any help with figuring this all out is greatly appreciated!
-Kacper
