my Axxb-e or mach3 or mach3 Plugin has a little Problem.
The Problem ist the direction look's to work the CNC works and changes the direction.
But the Problem is ports and pins, when i Change there direction low or high nothing changes (it should change the direction configuration).
I have an gantry and have to change the direction of the Y Slave Axis.
I have the problem since the first day but I used steppers and I changed the pinning to change the direction, but now I changed to JMC servos and can't change the wirering.
Can somebody help me?
Best wishes Daniel
