Not the start/stop frequency is infinate, but the acceleration can be about infinate below the start/stop frequency.
And ofcourse infinate is only a theoritical thing, better to say very high, but it is longer than to write "infinate".
cncdrive wrote:With servos if there is enough step buffer size then you could use high acceleration and the servo ofcourse will not loose steps and will not fault if the step buffer size is high enough.
E.g. in our DG4S drives it is setable upto 20000 steps.
So, the PID will work out the error and the motor will accelerate and deccelerate and reach target positions based on the position error, so as soon as the error goes high enough the PID loop push the throttle accelerating the motor to it's limits.
Robertspark wrote:"start/stop frequency" >> Maximum starting frequency (fS)
beefy wrote:At my set acceleration, my Z axis simply moves too far, even from a modest Z speed of 1500 mm/min and a THC update rate of 100 times/sec.
Users browsing this forum: No registered users and 26 guests
