by cncdrive » Mon Mar 28, 2022 10:10 pm
This is because your profile file got broken. This happens if the computer gets shut down while the UCCNC is saving the settings, so the file gets broken.
The solution is the create a new profile file and to make the settings for your machine again or if you have a backup copy then overwrite the profile file with the backup.
You can also enable the autobackupprofile plugin which creates backups from your profile file which backups you can use to recover from a problem like this.
