Screenset file not fund
Postby SunriseKreations » Sun Mar 27, 2022 2:42 pm
Not sure what happened. I shut down my machine like normal last weekend. Controller off then program close. Went to use it today and am now getting a screenset not found error. I have never even played with screen sets. How do I get past this? I have re installed UCCNC but it will only run in demo mode. I must be overlooking something simple
SunriseKreations
Re: Screenset file not fund
Postby SunriseKreations » Sun Mar 27, 2022 4:15 pm
I have reinstalled the software and moved my license over to it. I can get it to load but it is not the screen I used to have and now ma\y machine is not working at all. Kinda at a lose here
SunriseKreations
Postby cncdrive » Mon Mar 28, 2022 10:10 pm
This is because your profile file got broken. This happens if the computer gets shut down while the UCCNC is saving the settings, so the file gets broken.
The solution is the create a new profile file and to make the settings for your machine again or if you have a backup copy then overwrite the profile file with the backup.
You can also enable the autobackupprofile plugin which creates backups from your profile file which backups you can use to recover from a problem like this.
Users browsing this forum: No registered users and 35 guests
