Limit ports on Axbb-e
Postby gfacer » Mon Feb 14, 2022 9:46 pm
I'm sure I am missing something dumb but I have an Axbb-e setup with a foam hot wire machine and it has mechanical switches wired NO in series for limits.
I have them hooked up to negative side of port 2 isolated inputs, port 11 and port 12, and they are seemingly working correctly. Green light is on except when triggered, both on the controller and in the software.
However, I cannot set pin 11 or 12, port 2 as the limit pins in the axis set up. It won't save, and I am not sure why. The obvious reason online was using output pins and not input pins but these are clearly input pins so asking first!
Thanks, Greg
gfacer
Re: Limit ports on Axbb-e
Postby ger21 » Mon Feb 14, 2022 10:18 pm
The pins are 1, 2, 3, ...
They are labeled i1, i2, i3, ... Not 11, 12, 13
Postby gfacer » Tue Feb 15, 2022 2:45 am
My eyesight and not the greatest font choices on the default screenset combined to make that not obvious.
Thanks! The inputs are working, although at first I didn't realize I needed to add the same pin again to the home setting. It's being a while.
gfacer
Users browsing this forum: No registered users and 63 guests
