Turn software update?
Re: Turn software update?
Postby abaeck » Fri Nov 03, 2023 10:23 am
I’ve been using the LinuxCNC post (just change extension to .nc) UCCNC for turning. New features are welcomed and certainly make it nicer experience.
abaeck
Postby Delco » Fri Nov 03, 2023 10:36 am
neodd70 wrote:has anyone made a post file for fusion 360 yet for the new Turn feature in UCCNC?
Interested as well , machine all wired up and ready to test
Delco
Postby neodd70 » Sat Nov 11, 2023 11:03 am
Just giving this a bump because what good is the turn feature without a post processor. Does anyone know of a generic post or any other post for Fusion360 that will work in the meantime for most of the basic features until an official fully featured UCCNC Turn Post is developed?
neodd70
Postby Delco » Sun Nov 12, 2023 5:33 am
I ended up using the mach3 turn post processor to start with.
Delco
Postby asuratman » Sun Nov 12, 2023 6:48 am
the turn software not released yet, no UCCNC Turn Post is developed ?
asuratman
Postby beefy » Mon Nov 13, 2023 6:01 pm
Post processing is normally the last stage of cam software.
Example, Mastercam, Sheetcam, Fusion 360, etc, all do post processing at the end.
So talking about post processing here won't get one developed. UCCNC is mainly a CNC controller, that uses the gcode that has been spit out by a cam post processor.
Instead go to the specific forum for the cam software you intend to use and ask about a post processor for UCCNC turn there.
beefy
Postby Vmax549 » Thu Nov 16, 2023 3:22 am
The LinuxCNC or the Tormach Pathpilot turn posts should work fine for that until a proper one is created.
Just a thought, (;-) TP
Vmax549
Postby asuratman » Tue Nov 21, 2023 2:35 am
just wait for uccnc turn software released, uccnc and mach3 is almost the same. no more learning for linux, too tough too much controller to take care of.
asuratman
Postby cncdrive » Tue Nov 21, 2023 12:54 pm
UCCNC turn software was already released, you can find it in the test releases topic of the forum.
Postby asuratman » Wed Nov 22, 2023 2:24 am
Thanks for the info, I never check that test release forum. I have installed it, I will be busy today to learn this turn software.
asuratman
