uc 100 problems
uc 100 problems
Postby cousinit75 » Sun Jan 09, 2022 5:16 pm
hi has anyone had any difficulties with the software that is supposed to sort out the problem of using a paralell cable. Im talking about the uc100 that lets you use the usb connection. I bought the cable ffom CNCFORYOU and downloaded the needed files. But having problems with the install of the setup.exe. can anyone help?
cousinit75
Re: uc 100 problems
Postby cncdrive » Tue Jan 11, 2022 10:20 pm
what problem do you have?
Re: uc 100 problems
Postby JohnHaine » Wed Jan 12, 2022 5:24 pm
Well I just successfully installed the files on a WIN10 laptop and an XP desktop in the workshop, and it connects to the UC100 fine and it drives my machine as well. I had no problems with either installation.
You say you bought the cable, I assume you bought the actual UC100 as well?
Could you give more information about your configuration and what problems you are seeing?
JohnHaine
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 11:05 am
Hi I managed to sort out the install but now i have another problem. i have movement in only one direction on X and Y and nothing in the z. All motors have power to them the lights on the uc100 controller are solid green and solid blue. I have uploaded the motor outputs that was originally on the cnc when i got it and then what is on it now and what the instructions of the controller came with hope this helps.
what the cnc came with
cousinit75
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 11:07 am
what is on the cnc now
what the instructions for the contoller came with
cousinit75
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 11:08 am
the pic of whats on the mach3 wont upload
cousinit75
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 11:13 am
What's on mach3 now
Tried resizing pic
cousinit75
Re: uc 100 problems
Postby ger21 » Fri Jan 14, 2022 1:28 pm
The pin numbers for step and direction are different. If you haven't changed any wiring, set them to match what they were before.
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 1:39 pm
Thanks that was a simple fix for the x and ybI know have those working,however I still have nothing for the z
cousinit75
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 2:31 pm
Here is my control box the controller on the far left is my Z, it has two lights one solid red and a green one that lights when the button is pressed for the Z to move, and my DROs are moving for the Z aswell.
cousinit75
