Profile
Profile
Postby naijin » Thu May 08, 2025 1:10 pm
Hi there, I have a problem that is driving me crazy, two weeks ago my old faithful PC up and died, I replace it with a more updated version, installed UCCNC ver1.2113, Gery's 2022 screen,connected to the AXBB-E and booted up the computer
and here is where my problem started, All booted up, the UCCNC with screen 2022 all the lights on the Axbb-e lit up (two green and one blue/purple) but there was no movement of the axis, loaded my profile from the previous computer, went into settings and loaded the said profile, got message saying the profile was loaded OK, pressed Apply Setting and Save, I tried all the axis and they all worked well.
I turned the computer OFF and turned it back ON, it all booted up OK but with the default Profile, I went through same procedure probably ten or so times but the result was still the same it started with the default profile.
Before I start pulling my hair out(not much left anyway) does anyone out there know how to over come this problem I would be more than happy to hear from you.
Cheers
Nick
naijin
Re: Profile
Postby ger21 » Thu May 08, 2025 4:25 pm
How are you starting UCCNC? If from a desktop shortcut, the shortcut needs to point to the correct profile. Right click on the shortcut, choose "properties", and the target should look like this:
C:\UCCNC\UCCNC.exe /p Profilename
If you are not creating a new profile with desktop shortcut from within UCCNC, then you need to add the /p Profilename yourself. Make sure you leave a space before and after the /p.
Users browsing this forum: Bing [Bot] and 4 guests
