Hi to all
I'm in a process to make a retrofit in a tekna Cnc dedicated to machine aluminium profiles with just a few cycles.
To avoid to make each file each time we change profile and dimensions of that profile i have thought if it will be possible to ask someone familiar to c language that can make a plugin to use in uccnc, i can pay for that work and then share to others with no problem.
I attach the image i was thinking to know your best opoinions if this is possible. If so it is a huge help to retrofit this machine and to our work.
The letters are the variables but can be modifyed for better if there is a better opinion and the numbers in circles are for options about on each option we want to work.
thank you in advance, regards,
Ricardo
