I am not sure whether it is software or hardware problem - here a description:
rarely, happens in around 3-5% of machine turn on procedure (and it also happened few times in normal operation with manual movement using controller). My CNC is equipped with UC300ETH-5LPT and ihss60-36-30-21-38 jmc CL Steppers. Maschine starts in "reset" mode, after I unreset it I usually do "homing" procedure. Sometimes instead of doing standard Z Axis slow movement up (250mm/min), maschine makes rapid movement in other Z direction (down), and after short distance, the stepper is going into Error (probably, due to excess speed/accelleration). It makes sound as if it was trying to make G0, Z-axis down. This usually happens in homing, but also sometimes it does this error on diferent axis while manual jogging. Can anybody help me narrow down the issue? I might try to record the video, but since it happens not often it is hard to film it.
thanks,
Kris
