Autoleveler Plugin.
Re: Autoleveler Plugin.
Postby cahit » Thu Nov 01, 2018 8:40 pm
Hi dezsoe, Robertspark,
i am rewriting a hole new version of the autoleveler.
will follow these suggestions. but I can not say when it is finished it can take a while. sorry for that.
because I am not a professional programmer. and I do not have much time to program. but I will do my best.
take care...
cahit
Postby CADdy » Sun Nov 11, 2018 8:59 pm
Hi Cahit,
sorry to bother you. Version 1.0049 of AutoLeveler isn't working with my UCCNC Ver. 1.2047. No entry of it is present in the window "Plugins Configuration". If I use the older version 1.0045 (date 23.10.17) then the entry of AutoLeveler is shown. System is a Windows 7, 32 bit. What am I doing wrong?
cheers
Peter
CADdy
Postby dezsoe » Sun Nov 11, 2018 9:18 pm
As I wrote in August it runs only on the test versions. (It is not compiled to all versions.) You can read in one post before yours that he is working on a new version with all the reported problems solved.
Postby CADdy » Mon Nov 12, 2018 7:27 pm
Hi Dezsoe,
you are right! I've reading all posts again and I understand now. Thanks a lot.
Cheers
Peter
CADdy
Postby HuguesP » Wed Jan 02, 2019 7:49 pm
I would like first to thank Cahit for the work he puts making this project alive.
I would also like to know where i can find information about how to use the pluggin and and would be all the settings i should enter according to the job i need to do and my machine.
thank you
Hugues P
HuguesP
Postby mr_cg » Mon Mar 25, 2019 8:44 pm
@ cahit
Many thanks for sharing this great autoleveler plugin.
Unfortunately i do not understand how to create the digitize file so that i can apply the scanned leveling to different gcodes.
How to save the digitize file on harddisk?
mr_cg
Postby cncdrive » Mon Mar 25, 2019 10:05 pm
M40 : start collecting probe datas.
M41 : save collected probe datas.
Autoleveler Plugin v2
Postby cahit » Wed Jun 26, 2019 2:02 pm
Hi All,
who wants to test the version 3 of auto leveler that is under development.
so far the visual speed or rendering gcode?
if there are any problems then please report with the gcode like large files ...
it is written with the use of opentk and x64 compaible ...
cheers!!
Cahit Ates
AutolevelerCA.zip
(43.07 KiB) Downloaded 1086 times
cahit
Postby cahit » Mon Jul 01, 2019 7:58 am
hey guys what do you think of this so far...
many improvements in speed, specially large files and UI...
but there is still much to do...
AutolevelerCA 3.012.zip
(37.63 KiB) Downloaded 1100 times
cahit
Postby cahit » Fri Jul 05, 2019 3:15 pm
hi,
this is an update for test purpose....
added:
perspective/orthographic views...
save last settings in register so you do not have to enter every time...
settings and help button activated...
made some invisible improvements...
It doesn't matter if you use comma or dot when entering data...
red colored buttons has yet to be coded...
I must not forget to say that this version of autoleveler v3.017 is for UCCNC v1.2110
whach this video at https://www.youtube.com/watch?v=MTdVAOK ... e=youtu.be
cheers for now...
AutolevelerCA 3.017.zip
(279.45 KiB) Downloaded 1237 times
cahit
