I2R 8 Profile Settings
Postby shurst77 » Wed Mar 05, 2025 10:03 pm
Does anyone know where to get the profile settings for a I2R 8? Bought used CNC machine without any software.
shurst77
Re: I2R 8 Profile Settings
Postby cncdrive » Thu Mar 06, 2025 2:00 am
I think the best source is the manufacturer, ask the I2R CNC company.
Postby shurst77 » Thu Mar 06, 2025 2:46 am
I have submitted several requests to I2R, but no responses for 2 weeks now.
shurst77
Postby cncdrive » Thu Mar 06, 2025 9:50 pm
We don't have the exact wriing/settings of these machines, sorry.
You could try to check the control box and check the wiring to figure the connections, then set the port and pin numbers according to the connections.
These machines using AXBB-E controllers, you can find the datasheet and pinout on our website.
You could also try to email StoneyCNC in the UK, they might be able to help you with the informations you need.
Postby heffer86 » Fri Mar 07, 2025 5:24 am
cncdrive wrote:We don't have the exact wriing/settings of these machines, sorry.
I sent him my i2R profile.
heffer86
Postby shurst77 » Sun Mar 09, 2025 3:17 am
Thanks to everyone... information really helped. X,Y,Z all moving now. Spindle wont turn on. Looking at the Pin out for the AXBB. I'm guessing the settings in UCCNC should be changed to PWM instead of a relay.
shurst77
Postby cncdrive » Sun Mar 09, 2025 2:43 pm
You should setup the PWM spindle and you should also set the "Spindle PWM -> Analog ch." to 1, this attaches the analog output #1 to the spindle PWM and will output a 0-10V analog signal on the Analog Output 1. of the AXBB-E.
You should also set the M3 relay to give your VFD a start signal.
Postby shurst77 » Sun Mar 09, 2025 7:19 pm
Thanks...we have a working spindle now. U wire to the spindle was not connected to inverter. Thanks again...will post some pictures of projects.
shurst77
Postby cncdrive » Mon Mar 10, 2025 9:57 pm
OK, good to see you got it working.
Postby SBird » Fri May 09, 2025 4:16 pm
Hi I have just done exactly the same with a I2R 4 without any files and I2R not responding to any requests would someone kindly share their profile with me if possible.
SBird
Users browsing this forum: Bing [Bot] and 5 guests
