cncdrive wrote:We don't have the exact wriing/settings of these machines, sorry.
You could try to check the control box and check the wiring to figure the connections, then set the port and pin numbers according to the connections.
These machines using AXBB-E controllers, you can find the datasheet and pinout on our website.
You could also try to email StoneyCNC in the UK, they might be able to help you with the informations you need.
