Hi Russ you can still get teh switch kits
https://learn.sparkfun.com/tutorials/ro ... -guide/all
Vmax549 wrote:Hi Russ, IF you are not using teh analog inputs you can use them to run teh 2 rotary switches. You would set teh switches up as a string of resistors and measure teh voltage at each selection. The create a macroLoop to use teh values to make selections.
Just a thought, (;-) TP
