Hi Terry,
I started writing this menu plugin before I decided just to put all wizards into 1 plugin. It needs a button created on screen with # 44444. I can make it be able to be called with a macro/mdi if any 1 needs or prefers it.
Vmax549 wrote:Dan here is a thought, Instead of having to create a NEW button on screen simply setup the wizard as a hotkey in UCCNC I use {ALT_W} to call your Wizard up instead of creating a new screen button.
(;-) TP
[MyPlugins]
Wiz1button=44444
// The bool onscreen parameter is true if the button was pressed on the GUI and is false if the Callbutton function was called.
public void Buttonpress_event(int buttonnumber, bool onscreen)
if (onscreen)
if (buttonnumber == 128)
Vmax549 wrote:It is odd that the hotkey will start the Wiz but not Callbutton().
(;-) TP
dezsoe wrote:I think the difference is in the sample code:
- Code: Select all
if (onscreen)
If you check the onscreen value then Callbutton won't work. I did the same some time ago, reported to Balázs as an error. He told me to read the comment before the function declaration...
Edit: Hotkeys also make GUI calls.
dezsoe wrote:To prevent key code collision you could have a key in the profile to define the button code. E.g.:
- Code: Select all
[MyPlugins]
Wiz1button=44444
On startup the plugin could read this key (in Init_event) and check the read code in Buttonpress_event.
