Multiple Macro Button
Postby Dan911 » Sun Jun 03, 2018 1:06 pm
This plugin is going to be of great use to me and thought others may find use. I have many macro's and plugins I like to have readily available
to me on screen but hate the clutter of many buttons and can't remember macro numbers to type into MDI or hotkey combinations.
On button press or hotkey it will give you a comboBox with a list on macro's/plugin's by name to choose from and press load. You will need to go to
plugin configure and setup.
In Configure window give a name and choose macro to call.
Setup instructions:
1. Put plugin in UCCNC plugin folder.
2. Go to plugin configure and check Call startup and Enable
You will need to create a button in screen edit and give it buttonnumber 4444 or setup a hotkey and use 4444 for function code.
Macro Menu.zip
(7.86 KiB) Downloaded 787 times
Re: Multiple Macro Button
Postby beefy » Sun Jun 03, 2018 9:27 pm
Thanks very much Dan.
I can see that coming in real handy.
Keith.
beefy
Postby Dan911 » Mon Jun 04, 2018 9:13 am
Thanks Terry and Keith, happy to see others can find use.
