markcadcam wrote:Dan911
Very nice work. This is perfect for one off type of parts. I will use it often. Thank you.
Thank you Mark I appreciate your feedback! If you find any issues/bugs please let me know.
Vmax549 wrote:HIYA Dan, I loaded up teh latest plugin to take a peak. It does not work here. I load teh plugin and teh main screen comes up. I select start a new file and nothing happens. I do get teh message about starting a new file but then nothing happens.
Any ideas ?? Am I doing something wrong ?
(;-) TP
(;-) TP
Dan911 wrote:I found this plugin very useful and been using quite often, each time I use I find a bug or something to tweak and been fixing as I went along. Unfortunately I haven't made a list but biggest that come to mind are.
1. In wizard "create part or path" absolute mode didn't work. (I mainly use incremental)...fixed
2. On slower comps sometimes may get and exemption when trying to access a file that was still be written. Created a check function...fixed
3. I removed the ability to call main menu with macro. It was causing a [STAThread] exemption I couldn't resolve. I like the way interface works and not going to change it.
Any problems I was notified about was fixed. I tried to update the help files since without a manual plugin can be useless.
Vmax549 wrote:Hi Dan , It is working ok now V6.
(;-) TP
epracefan@gmail.com wrote:Hi Dan and thanks for creating this.
Thought I'd give Wizard V6 a spin and have a problem. I hit Start to clear the temp file and created a 2" pocket .25" deep in 2 passes at X6,Y6. The generated Gcode has my Z plunging to -.625" right off the bat. The second pass moves to Z-.75".
What am I doing wrong?
Ed
