I just fitted a hard wired mpg
It works really smoothly after a bit of tweaking.
When selecting an axis x y or z everything is nice
But if I switch to none of the above the last used axis is still active.( I only have xyz wired)
Can you confirm this is correct. I'd prefer if it any axis was only active if selected so there's no chance of movement while putting the mpg back on its hanger for example if I accidentally knock the wheel
