Has 1.2103 been pulled?
Postby LBayZG » Mon Mar 12, 2018 3:59 pm
I've tried to download the latest UCCNC (ver. 1.2103). But I get 'file not found'.
Has this version been pulled?
LBayZG
Re: Has 1.2103 been pulled?
Postby cncdrive » Mon Mar 12, 2018 4:06 pm
Postby Derek » Mon Mar 12, 2018 5:09 pm
I'm running 1.2103 on the Alliant. Seems to be doing fine. Should I downgrade or can you tell me what the bugs were? It has the fix for the tapping issue and the UC-300USB so I hate to change if I don't need to.
Derek
Derek
Postby ger21 » Mon Mar 12, 2018 5:52 pm
Probing doesn't work if your macros use the vars.
Postby cncdrive » Mon Mar 12, 2018 10:35 pm
What we found is a syncronisation problem of the homing while g-code is running.
It is because of the issue fix with the full circles which I described in the release notes, that if a full circle was coded with first the start point and after some other codes, e.g. text macros which made the controller to syncronise and only then the arc coded then if the starting point of the full circle was not on the grid defined by the 1/steps value then due to the syncronisation of the coordinates this could possibly caused the controller to not cut the full circle, because the resyncronised real coordinates made the full 360° of the circle to around 0°. We fixed this problem with changing how and when the controller is syncronising, but forgot that the homing should be also changed how it syncronises, so now when the home is called from g-code (G28.1) that does not work properly and because it is not syncronising the coordinates the G28.1 could cause issues, like more than one axis moving when homing and axes reversing back to the coordinates where they started and things like that.
Since some CAM programs posting G28.1 into the g-code files and so it might be often used we thought it is better to pull this release because of this issue.
The other thing is what I think Gerry reported is that the probing always give back 0 values in this test release which is due to the upgrade of how the #vars update. It is also noted in the release notes.
