Bear with me as I'm still learning. I successfully used the screen edit function to move some buttons around. However, Since I moved the DRO locations I also needed to change the background file that labels them. I found "background1.png" and made the necessary edits. Here's my problem. The old background1 file seems to still be loading. The icon that I use to launch UCCNC uses a "/p SC2-600_3DProbe" to specify the profile to load from the "\Profiles\" folder. The .pro file has a "mainscreenfilename=Stepcraftscreenset_3DProbe" which I assume it gets from the "/Screens/" folder. The "Stepcraftscreenset_3DProbe.ssf" file has a "string bitmapfolder = "BMP/Stepcraftscreenset_3DProbe/" " entry which is where I assumed is the folder where I should be putting the edited "background1.png" file. A search of the .ssf file showed it contained no entry for "background1.png" but many entries for all the other background files. How does UCCNC find and locate the appropriate file? The background file I edited is located in the "UCCNC/Flashscreen/BMP/Stepcraftscreenset_3DProbe/" folder.
Attached is the edited background file with the DRO labels moved to the right by 40 pixels.
I'm stumped.
