Synchronous O/P M10.1 still under development ???
Postby beefy » Fri Feb 23, 2018 8:54 pm
Some time ago, Andrew (Shad) asked for a new synchronous O/P which is not controlled by M3/M5, i.e. completely independent.
Last I heard it was being developed and would be called M10.1 / M11.1
Is this still some time away before it will be ready ?
Cheers,
Keith
beefy
Re: Synchronous O/P M10.1 still under development ???
Postby beefy » Sat Feb 24, 2018 4:43 am
This was the thread where Andrew asked for this new feature:
viewtopic.php?f=16&t=948&start=0
beefy
Postby shad » Sat Feb 24, 2018 6:39 am
As far as I know, this has already been implemented and is being tested. Balazs said that the new release will be very soon.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby beefy » Sat Feb 24, 2018 9:35 am
Great, thanks Andrew.
beefy
Postby shad » Sun Feb 25, 2018 4:14 pm
Looks like M10.1/M11.1 commands still not added in the 1.2103 release :(
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby shad » Thu May 17, 2018 7:33 am
Hello!
Any news?
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby cncdrive » Thu May 17, 2018 3:18 pm
Hi Andrew,
We still working on it sorry. Will be available in next release.
Postby cncdrive » Fri Jun 15, 2018 11:12 am
This function is now available in the new 1.2105 test release.
We've added 10pcs of syncronous on/off outputs M10.1 to M10.10 and M11.1 to M11.10
Postby Robertspark » Fri Jun 15, 2018 11:25 am
I.ll update the macro manual later with the new checkboxes and fields if you're doing any macros / screensets, but I guess that they will just be called directly from within gcode as digital only IO's (not PWM as per M10 Qxxx
+ new Function: int Ismacrorunning(int macronumber)
{note the screenset >> Help >> Supported M-codes has not been updated to M10.1...10}
Postby cncdrive » Fri Jun 15, 2018 11:32 am
Hi Rob,
OK, thank you for updating.
The M10.x/M11.x are on/off syncronous switches, they have no parameters, no PWM, they just switch on/off in syncron with the motion.
The Supported M-codes list had been updated, but these codes are not supported by the USB controllers, only the ethernet ones. You probably checked the USB versions screen, those do not support these codes, so those screens do not have these codes listed. You probably checked a USB controller screen.
The UCCNC manual describes that only the ethernet controllers support these.
Return to CNC Plasma
