thanks jason- thats what i needed to see.
In the example profile when it gets to teh corner and wraps around (90deg) it checks teh next block and see that it will NOT interfere with teh next line. HAD it looked one more block it would have seen there was an intersecting line and that intersecting line would be closer than teh tool radius indicating a gouge. IT could do 1 of 2 things ERROR out OR change teh path to fix teh problem I would say that a 3 block look ahead could find 99.9% of all collisions. It could SEE a situation such as a small area that teh tool could not fit into. It would check for X and Y interferences over 3 blocks.
In teh Fanuc examples teh controller simply ignored any segment that was an interference and rewrote teh path to teh next clear segment that did not violate teh tool Radius.
IIRC there were several examples one was a step down like Ger example andn teh other was a notch that the tool could not access because the tool was too wide. IF you try that in UCCNC it will destroy teh part. I did test that part as well. It will turn a .250 notch into a 1" notch(;-) BUT that is MORE programmer error than machine It just did what I told it to do. It did not know I was just kidding
Users browsing this forum: Google [Bot] and 13 guests
