Hi Balazs,
no idea where this error message is coming from:
1) Is it generic Windows.
2) Is it the Neuron plugin
3) Is it UCCNC
I Googled for this specific message but got no results so I'm guessing it's either UCCNC code or the Neuron plugin code giving the message.
Anyway, I have my old XP (service pack 2 !!!) running Mach3 with the MP3000-DTHC plugin from Candcnc. I'm installing UCCNC on this computer.
Using version 1.2101 but also had exactly the same problem with v1.2046
UCCNC installs fine and starts fine, both standard and plasma profiles.
I copy all the Neuron files to C:/UCCNC and start the NeuronPlasma profile and select the device (UC400ETH). After that point UCCNC continues starting but halts with an error box:
I click OK in the error box and UCCNC finishes starting, and the Neuron Run tab layer is showing as normal. However, I have no idea what that error message means and if the program may run incorrectly at some point.
Keith.
