by cncdrive » Tue Jan 16, 2018 9:09 pm
Blank or 0? The 2 things are not the same!
If talking about basic/standard DROs, (e.g. an axis velocity value) the value goes 0 on startup if the value for the DRO saved in the profile file is 0.
Or if the screenset it limiting the value for the field.
E.g. if the maximum value of a DRO is set to 5 and you want to write 10 to it then it will still have a value of 5, because the screenset setting limits the max. value to 5.
