Plug Inns
Plug Inns
Postby naijin » Thu Jan 18, 2018 11:57 pm
Hi there, just a quick question, Mach 3 has plug inns for some peripherals and software on their web site, does UCCNC also have plug inns or do you use Mach 3 Plug Inns ?
Regards
Nick
naijin
Re: Plug Inns
Postby ger21 » Fri Jan 19, 2018 12:28 am
UCCNC has it's own plugins. Several are already installed.
Re: Plug Inns
Postby naijin » Fri Jan 19, 2018 9:28 am
Hi Ger21, thanks for the quick reply, guess I will find the plugins on their site.
Regards
naijin
Re: Plug Inns
Postby A_Camera » Fri Jan 19, 2018 12:33 pm
But Mach3 plugins won't work in UCCNC and vice versa, UCCNC plugins won't work on Mach3, except the ones made for the CNC Drive motion controllers to enable using Mach3 with them and these can be downloaded from CNC Drive. UCCNC has plugins for some things, however, to use UCCNC you MUST have a motion controller made by CNC Drive. You can't use any other. The plugins available for UCCNC are for other type of peripherals, like VFD, auto levelling, 3D printer and so on. All requires that you have both UCCNC and one of their motion controllers plus a license. So which plugin are you interested in?
A_Camera
Re: Plug Inns
Postby cncdrive » Fri Jan 19, 2018 12:47 pm
Josef, one little correction: UCCNC plugins work also in demo mode of the UCCNC and for that no motion controller is required. For example the Modbus plugin can be useful even in demo mode.
Re: Plug Inns
Postby A_Camera » Fri Jan 19, 2018 1:00 pm
cncdrive wrote:Josef, one little correction: UCCNC plugins work also in demo mode of the UCCNC and for that no motion controller is required. For example the Modbus plugin can be useful even in demo mode.
That is true. I forgot about that. Thanks for the correction.
A_Camera
Re: Plug Inns
Postby naijin » Thu Jan 25, 2018 12:09 am
Hi A_Camera, I was wondering if there is a plug in for the XHC wireless Pendant, and if anyone is using one, how is the performance and are there any problems??
Regards
Nick
naijin
Users browsing this forum: No registered users and 37 guests
