Help for repetitions counter
Postby dasvar » Thu Dec 14, 2017 4:27 pm
I am using a subroutine to repeat a set of motions N times and I want to have a textfield on my screen that shows how many repetitions have already been done. How can I do this?
Harry
dasvar
Re: Help for repetitions counter
Postby Robertspark » Thu Dec 14, 2017 7:56 pm
Edit your screen using the screen editor tool on the configuration tab
Add a text box, give it a unique number say 5000.
You may need to add a button to clear / reset the textbox value (it depends how your macros run)
Then edit your macro such that it stores the current cycle number and increments it by one every time it is run
And a line of code that passes this count to your textbox that you cleated.
At the end of the macro you can create some code that will reset the count to zero and clears the field
Postby dasvar » Fri Dec 15, 2017 8:43 am
Thank you both for your help, I think that I can handle it now.
Harry
dasvar
Users browsing this forum: Google [Bot] and 33 guests
