MODBUSEZ Plugin
Re: MODBUSEZ Plugin
Postby Battwell » Fri Dec 08, 2017 4:11 pm
Correct settings
Re: MODBUSEZ Plugin
Postby Dan911 » Fri Dec 08, 2017 4:32 pm
Battwell wrote:
The attachment IMG_3747.JPG is no longer available
Correct settings
Battwell could you please do me a favor and test the current read in Modbus V15 plugin.
I know control works well been tested/used for weeks but I had the read being sent wrong and hoping you could check with plugin below'.
Using current draw register and put 10 in the divideby field.
Big thanks in advance.
MODBUSEZ.zip
(12.86 KiB) Downloaded 968 times
Re: MODBUSEZ Plugin
Postby Battwell » Fri Dec 08, 2017 6:40 pm
no its got a value- but not reading amps register.
testing on ecogoo register is 3002h mapped to screen textbox i created 20010
Re: MODBUSEZ Plugin
Postby Dan911 » Fri Dec 08, 2017 10:24 pm
Battwell wrote:no its got a value- but not reading amps register.
See what I did. So frustrating doing this without being able to check.
Thank You
Re: MODBUSEZ Plugin
Postby Sword » Fri Dec 08, 2017 11:12 pm
I'm new to UCCNC and just came across this. Haven't read everything here or on CNCzone yet, but wanted to ask as as to whether or not this would work with a Delta M series VFD. It does have a RJ45 connector. I also have an older USB RS485 board and drivers for Win7 for it that I had used previously to control rpm on a Yaskawa VFD. This is the board
Scott
Sword
Re: MODBUSEZ Plugin
Postby Battwell » Sat Dec 09, 2017 12:38 am
If you redo it I can test
I have vfd connected to a spindle by my pc chair at the moment- along with other development bits and pieces.
Visitors can tell I'm divorced lol
Re: MODBUSEZ Plugin
Postby Dan911 » Sat Dec 09, 2017 10:33 am
Battwell wrote:If you redo it I can test
Thank you Battwell, I will be at my friends shop this morning and will test there, I already have a serial monitor loaded on his comp
and I will be able see and confirm if working or where problem is. This probably won't take more than 10-15 minuets than going back and forth here.
if I don't get away from desk I'll be divorced also. :idea: LOL
I really appreciate your help and offer,
Re: MODBUSEZ Plugin
Postby Battwell » Sat Dec 09, 2017 10:39 am
cool- get it done and il run it on my machine.
got all 3 vfds running modbus now :-)
just have to do yaskawa, & control techniques
Re: MODBUSEZ Plugin
Postby Dan911 » Sat Dec 09, 2017 10:50 am
Battwell wrote:cool- get it done and il run it on my machine.
Great..I think there aren't much Modbus users because of being a little complicated, but as you see it's really not. Like using the telephone, you need the right number to get through.
Re: MODBUSEZ Plugin
Postby dezsoe » Sat Dec 09, 2017 8:06 pm
Where can I find the current version of ModbusEZ? I have a Commander SK VFD on my table with a large motor connected and would like to test it with your plugin. It already works fine with a macroloop and the ModbusMaster plugin.
(I have all these things in the living room now, lots of Arduino and PIC stuff on my table, but it seems, I will not be devorced. :) My wife never saw anything else around me.)
