I'm working on a new screenset, and ran into a problem.
I started with the default screenset, and deleted all of the elements from the Run screen.
When I tried to add a Toolpath Window, it would add it to the upper left corner, and when I clicked on it, it would cause an exception. I could not select it or do anything with it. (I'll post the exception error in a separate post)
I then opened the .ssf file, and saw that it was on layer 1.
Changing it to layer 2, and restarting UCCNC, it was now in the center of the screen, and I could now edit it normally.
If you Edit Screen, and change a toolpath window layer to layer 1, then select it , it will cause a crash.
I don't know why my elements are being created on layer 1? Would it be possible to specify the layer when adding items to the screen?
