How do I determine what value to set?
What are the consequences of setting it too high?
What are the consequences of setting it too low?
Thank you.
dezsoe wrote:- On the other side, some drivers need longer pulses on their input, so you cannot go too high. (The higher frequency the shorter pulse.)
rowka wrote:Mach3 values (using the machine OEM supplied xml file)
5833 steps/in
160 in/min max velocity (2.667 in/sec)
therefore ~15.5kHZ
The OEM xml file sets it at 35kHz
I have installed UC300ETH-5LPT, and UCCNC.
Should I continue with 35kHz?
Robertspark wrote:How is acceleration affected by kernel speed / loop?
i don't think you are correct with that one, as acceleration is a function of time, i.e. the pulse width (time between pulses) is greater at the start of the acceleration curve, and the pulse width gets less as the machine gets up to maximum velocity (minimum pulse width)
This means that Vmax is reached after 12.64mm travel distance and 0.19s time. During the 0.19s the stepper must receive 5056 pulses,
Users browsing this forum: Bing [Bot] and 35 guests
