All,
First time poster, very new at this CNC thing. I'm currently re-wiring everything on my mill and am planning to use UCCNC as the control software with an ETH400.
Basic hardware:
ETH400
CNC4PC C23 BOB
Hitachi WJ200 015SF VFD
Marathon 3P motor with Dynapar HS35 encoder.
The encoder wiring to the VFD seems pretty straight-forward. Encoder A+ to "EA" pin, and B+ to "7" pin and set the parameters to match.
Here's my question: How do I get the encoder signal from the VFD to UCCNC?
The software setup asks for A & B pins. The VFD has an "EO" pin, which is the "pulse train out" terminal. I think this sends a 10VDC signal - but of what?
My BOB requires 5VDC inputs - maybe a resistor would help here to drop the voltage. But does anyone have an idea how I can get the A+ and B+ signals to the BOB so UCCNC can pick it up?
Can I split the signal from the encoder upstream of the VFD and send the A+ & B+ to the BOB and the VFD at the same time?
Or am I missing something fundamental here about encoder signals and/or UCCNC?
[If this isn't the appropriate forum since this may be more about the VFD than UCCNC, let me know and I'll move over to CNCZone. I'd just planned on lurking here as much as possible while learning the software and ETH400.]
Spumco
