Finally getting time to redo my Bridgeport. Here is what I have.
UC-300ETH/ 5LPT. 2 HDBB2 BOBs. DG4S 16035 drives. Brand new Intel PWLA8391GT NIC. 5VDC supplied by 2.5A wall wart.
Test program runs the Y axis to 10" and back to 0". It does this cycle 100 times. At the end of the cycle it is off by .014-.017" in the same direction each time. If I switch out the UC-300ETH/ 5LPT with a UC-300USB/ 5LPT and run the same program it's within .0005". I have tried two different computers. Two different network cables. It is absolutely repeatable. I switched it back and fourth 3 times and got the same results. Both are running at 100 kHz.
I get the same results with both 5LPT boards.
Both computers were dual core with external graphics cards. One was XP and the other was Windows 7. The network cables tested were Cat5E and Cat7.
This is the same issue I was having earlier with the M44B but at the time based on others comments I concluded that was the problem. I also had no way to test it at the time due to lack of testing components. The last time I tested it I tried 2 different network cards.
I'm really at a bit of a loss as to what to try next.
Derek
