ger21 wrote:No, the exponent is coming from your math operation, and is a C# issue, not a UCCNC issue.
merrick wrote:ger21 wrote:No, the exponent is coming from your math operation, and is a C# issue, not a UCCNC issue.
It is not strictly my math operation. These math operations are routine in macros, including yours. I just happen to have a corner case that jumps out.
C# has a way to convert double to string without using exponent format, but as far as I know, it is not available in the UCCNC C# macro environment. Blaming it on C# is not a solution because UCCNC has control of the C# macro environment.
I reported what I observed in hope of improving the software and benefiting all users. Now that I understood the root of the issue, I'll hopefully find a work around solution.
