UCCNC Sycotec 4033 AC Spindle
Postby figher_ionut » Thu Aug 24, 2017 9:39 am
I have a cnc machine from the bungard whose controller I modified and adapted for the ucccc software.
The controller I'm using is uc100.
The spindle chuck is pneumatically driven and I would like to do it by pressing a button in the uccn interface. How can I do this?
The cnc machine is equipped with ATC for 14 tools but I did not intend to use it for the time being.
figher_ionut
Re: UCCNC Sycotec 4033 AC Spindle
Postby dezsoe » Thu Aug 24, 2017 11:03 am
Add a button to your screenset. (See documentation for details.) Use a button picture like yellowempty_down.png and yellowempty_up.png to show chuck state. Set buttonnumber to 20105.
Add this macro to your macro folder as M20105.txt:
// Chuck open/close
if (AS3.Getbuttonstate(ChuckButton))
{        // Chuck is open -> close it
  if (OpenChuckOn1)
    exec.Clroutpin(ChuckPort, ChuckPin);
  else
    exec.Setoutpin(ChuckPort, ChuckPin);
  AS3.Switchbutton(false, ChuckButton);
else
{        // Chuck is closed -> open it
  if (OpenChuckOn1)
  else
  AS3.Switchbutton(true, ChuckButton);
#Events
const int ChuckButton = 20105;                                        // Must be the same as macro and button number
const int ChuckPort = 1;                                              // UC100 is always port 1
const int ChuckPin = 1;                                               // Set this to the output pin for chuck
const bool OpenChuckOn1 = true;                                       // True if chuck opens on pin high level else set to false
If your chuck opens on low level output, change in the last line true to false. Set ChuckPin to your output. If you changed OpenChuckOn1 to false, only then add the following line to M99998.txt (it will set the output high on stratup):
exec.Setoutpin(1,1); // Port and pin, where port is always 1, pin is your output
