both of my vfd act the same way when connected to the mb2, i want to remove the keypads and see if there is a change..
thanks for all the ideas, will keep you posted
ger21 wrote:Did you change Parameter 05 as I said before? It should be set to 3.
cncdrive wrote:A+, A- and B+ and B- signals mean that you have a differential encoder.
You need to connect that to a differential line receiver (26LS32 or similar) with a terminating resistor or snubber. (Check the 26ls32 datasheet for example)
Or you could connect one of the signals only to an optocoupler input, e.g. the A+ to the serier resistor + anode and the ground to the cathode of the opto LED. And leave the A- unconnected. And do the same with the B channel to another input opto.
Do not anode connect the series resistor + A+ and cathode connect the A- etc. because if the BOB does not have a reverse polarity parallel protection diode installed then this connection could exceed the opto LED's input reverse breakdown voltage damaging the LED or if the optocoupler has a dual polarity LED (some optos are like that) then it will not work, because the LED will be powered with both signals polarities.
You can configure the MPG in the UCCNC configuration, there is an MPG A and B channel port/pin setting, configure those to the port/pin number where you connect the encoder signals.
The MPG knobs you can connect to other inputs and then add those port/pins to input triggers in the UCCNC and attach the required function to them in the input triggers.
tracar wrote:Details:
B- conected to 5v signal from MPG (A+)
C- gnd
E- signal out, to uc300eth, connect to any of the inputs on the mb2, or uc300eth
Users browsing this forum: No registered users and 32 guests
