I have went back to Mach 3 and loaded the uc400eth plugin and it works fine with the original settings ,so it is the angular A axis that is required for the fourth axis to work correctly.
I have put in a feature request to see if they will add this , please!!!!!!!!!!!
Is it ok to switch between the Mach software and the Uccnc with out creating a huge problem for myself?
