I have ordered some necessary parts to be able to use my CNC as a 3D printer. In the meantime, I have connected a 4th stepper and enabled the 4th axis, since that must be used as the filament feeder and done some dry tests. I had a look at the 3D plugin, but I must admit, I don't know what that is doing, other then starting the spindle, which was pretty scary because I didn't expect that pushing the fan on button actually would start the spindle. Anyway, here are a few questions.
What is that pluging actually doing and why is it needed?
Is there any documentation of that plugin somewhere?
Is it really necessary, and if yes, for which purpose?
It seems that I still need to use Slice3r to create Gcode, or is that wrong?
Anybody using this plugin?
How do you calculate the feed rate of filament for optimal results? Trial and error?
Thanks.
