I think this is being caused by it. This is with 1.2041. The last version I had upgraded to was 1.2037. I loaded the code and started to run it. I got no warning of soft limit when I pushed run. The tool was going along it's merry way and when it got to what I think was max travel on the Y it did a rapid over to a point in both X and Y and then continued machining. It stayed at the same Z level. Fortunately there was nothing in it's way. I rolled back to 1.2037 and when I loaded the code and pushed run I got the soft limit error. This is why I think it's related to that.
I'm in the middle of a job so I can't give you any more info than that but I wanted to get this posted so that someone else doesn't have a problem.
Derek
