UCCNC test releases posted in this thread
Postby cncdrive » Tue Sep 27, 2016 11:18 pm
UCCNC version 1.2023 version available for testing: http://www.cncdrive.com/UCCNC/setup_1.2023.exe
Bugs fixed:
- Timeout parameter did not save in the Modbusmaster plugin, problem fixed.
- Autoleveler plugin jogdisable issue was fixed by the developer, plugin updated.
- Probe did not work in some cases, problem fixed.
- Softlimits parameters did not download always properly, problem fixed.
- Plugininterface Getbuttonstate missing function was added.
Re: UCCNC version 1.2023 ready for testing
Postby Battwell » Wed Sep 28, 2016 12:46 am
I was going to email you re some missed probes! Will install today
Postby A_Camera » Wed Sep 28, 2016 11:22 am
Thank you. Will download and test it as soon as I can.
No news about radius compensation(G40, G41, G42) and Mach3 plugin for UC300ETH?
A_Camera
Postby cncdrive » Wed Sep 28, 2016 1:12 pm
Radius compensation will probably take months to be fully implemented and tested, it is not a weekend project, it is really complex stuff.
The Mach3 plugin for the UC300ETH targeted to be done by the 15.10 .. hopefully we can finish by the date.
Postby A_Camera » Wed Sep 28, 2016 1:25 pm
Thanks for the answer. Yes, I know radius compensation is not just a small fix, but thank you for the updates anyway. In the meantime, thank you for the quick fix of the Modbus timeout.
A_Camera
