paulcc wrote:Fixed 2017 A axis issue with newly created profile. Only problems remaining are 40 second save settings popup delay and Huanyang M3 not working in 2017 (works fine in default screenset profile).
Thanks again Gerry and CNCDrive for your continued attention!
Hi paulcc,
I use and tested 2017 screenset with all versions but what I forgot I did and failed to mention is causing this confusion.
You need to change the RPM field number is screen edit in 2017 screen set to 2451.
Use HY12, and using 2017 screenset go to screen edit and click on the RPM field and change number to 2451 and you will be good to go.
Sorry,
