Plunge cuts- help
Plunge cuts- help
Postby Battwell » Sat May 27, 2017 9:40 pm
Re: Plunge cuts- help
Postby Battwell » Sat May 27, 2017 9:41 pm
Postby Battwell » Sat May 27, 2017 9:44 pm
The first picture shows a straight line started with a ramped cut- notice the off co ordinate part at the bottom
The second picture shows a non ramped cut- perfect
No flex in cutter, work or head.
Any ideas
Postby cncdrive » Sat May 27, 2017 9:46 pm
Can you post the g-code of the code which has the issue?
Postby cncdrive » Sat May 27, 2017 9:52 pm
And your profile also please.
Postby Battwell » Sat May 27, 2017 9:53 pm
The title should be ramped cut starts
Strange thing is I can't see this movement on the dro. It is not in the code.
Machine is using servos- no overshoot. Very tightly tuned-
Postby cncdrive » Sat May 27, 2017 9:55 pm
I would be happy to run your code on a logic analyser using your profile to see if there is any command on the other axis, but for that I will need the g-code file and your profile file.
Postby Battwell » Sat May 27, 2017 9:55 pm
I will post a snippet of the code tomorrow, it's part of a huge file
Postby cncdrive » Sat May 27, 2017 9:56 pm
OK, but please make sure to post this exact part of the code and also don't forget to post your profile file.
Postby Battwell » Sun May 28, 2017 3:58 pm
email sent :-)
