V38 overridden doesn't always update
Postby Battwell » Thu May 25, 2017 4:34 pm
Does it only update after a tool change?
Doesn't follow analogue override on 300 eth
https://youtu.be/ojA7pwr9COs
Re: V38 overridden doesn't always update
Postby cncdrive » Thu May 25, 2017 11:19 pm
I have checked the issue and a condition check was missing, so the DRO is really not updating when the analog input is attached to the FRO and has to control it.
Both the overridden feedrate and overriden spindle speed DROs have this screen update issue now.
I've added the missing condition checks, so they will be OK in the next release.
Postby Battwell » Fri May 26, 2017 9:34 am
it must be hard as a programmer to catch every scenario every time.
keep up the great work. uccnc gets better all the time.
Postby cncdrive » Fri May 26, 2017 1:49 pm
Thank you Brendon.
Yes, you are right, it is not easy to think about all possible scenarios when coding new functionalities into the software,
because the software is already very complex with lots of things we have to think about when adding even simple functions.
But this is what the test versions are for, to find these kind of issues before the software version goes out to official release.
Postby Battwell » Fri May 26, 2017 2:15 pm
I may have found something else. Today all my ramping in cuts are not lined up with the actual co ordinates.
I.e. Any cut that starts with a ramp.
Il do more investigation later
Any cut not ramped into the work is fine
Il take a photo later to show exactly what I mean
