Analogue output on ETH 300
Postby formantjim » Thu Jan 02, 2025 3:10 pm
In the manual for the ETH 300 it shows that it has two Analogue outputs on the analogue Port with Pins 6,7,14 and 15 but does not say the polarity for the analogue output on these pins. Can anyone tell me which is positive and negative for these pins please?
formantjim
Re: Analogue output on ETH 300
Postby RsX » Thu Jan 02, 2025 6:29 pm
I think the the pins are duplicated.
So Ground is negative and Analog output is positive (either 6-7 or 14-15)
RsX
Postby cncdrive » Fri Jan 03, 2025 5:38 am
Yes, the pins are simply duplicated, the same function is connected to both pins on the 2 sides of the connector as per the users manual.
Postby formantjim » Fri Jan 03, 2025 6:13 pm
Wonderful guys thank you!
formantjim
