Modbus Master and Haunyang GT series Inverter
Re: Modbus Master and Haunyang GT series Inverter
Postby sebba » Sat Nov 02, 2024 2:09 pm
yes, sure, F0.01 = 2
it is like this for more than 5 years, with Mach3 and modbus control. even now, it is working fine under mach3
it is the same computer, same hardware, where I intend to switch from Mach3 to UCCNC
- YQWQ
sebba
Postby sebba » Sun Nov 03, 2024 9:29 am
I found the problem.
In VFD's settings:
F6.06 - Response measure - should be "0", which mean "Response at write"
It was "1", meaning "No response at write". I have no idea why I set it to 1, it was very long time ago. :)
It seems this response is not need it in Mach3 but required for Modbus Master plugin. Also, is still working in Mach3, too
And one more thing: the UCCNC register's value for on-off function should be 1, 2 or 5. If 0, the function return "Loop wait" error
Best regards,
Seb
- YQWQ
sebba
Postby sebba » Sun Nov 03, 2024 7:28 pm
me again!
one minor issue: I have a relatively big delay for M5 command.
after M5 command, the spindle keep running for 4-5, maybe 6 sec, then decrease rpm and stop
could be a modbus issue or else? what else?
my modbus config (from profile file)
[ModbusMaster]
Version=1.060000
Connections=1
Conn0="DZB200B",True,250,3,1000,RTU,COM10,9600,8,None,1,True,4
Conn0Fn0="ON-OFF-RESET",True,1,Write_SingleRegister,1,4096,0
Conn0Fn1="VFD Speed",True,1,Write_SingleRegister,1,8192,1
Conn0Fn2="VFD Error",True,1,Read_HoldingRegisters,1,4097,2
Conn0Fn3="VFD Status",True,1,Read_HoldingRegisters,5,12290,3
thank you
- YQWQ
sebba
Postby valhallaCNC » Mon Nov 04, 2024 1:33 am
Goto settings > spindle....there is a delay setting there
valhallaCNC
Postby sebba » Mon Nov 04, 2024 7:06 am
here? nothing
- YQWQ
sebba
Postby RsX » Mon Nov 04, 2024 8:48 am
Acceleration (sec)
look here, its function has been changed in the new version
https://forum.cncdrive.com/viewtopic.php?f=3&t=4899
RsX
Postby sebba » Mon Nov 04, 2024 10:06 am
Great, thank you
- YQWQ
sebba
Users browsing this forum: Bing [Bot] and 11 guests
