I bought the AXBB-E to use with my Gecko G540 so I could use ethernet to control the router and your UCCNC software. I am using the DB25 cable to connect directly to the G540 from port 3 on the AXBB-E.
With the G540 you wire your e-stop switch from port 10 of the Geckto through your e-stop and then to the negative rail of the power supply. I am using a 48v power supply to power the G540 and motors.
However, I don't know how I should wire the AXBB-E to recognize the E-Stop when Active. I tried setting the UCCNC software to use port 3 pin 10, but it does not recognized the E-Stop.
Can someone please help me with the correct setup?
Thank you!
