referencement axes et limit axes
Postby gilles974 » Sat Oct 26, 2024 7:29 am
hi
is it possible to use the 3 XYZ axis switch as both reference and software limit switch ?
à moi les copeaux
gilles
gilles974
Re: referencement axes et limit axes
Postby sebba » Sat Oct 26, 2024 1:41 pm
do you want to use a single input pin for 3 switches for 3 axis?
if parallel wiring you have to use NO switches. if serial wiring you need NC switches
it should work but only if no slave axis (like 2 steppers for same axis, master and slave)
- YQWQ
sebba
Postby gilles974 » Mon Oct 28, 2024 3:49 pm
hello sebba
d
i prefer to use NC contacts, there will be no slave axes
so it is possible to use one input for 3 axes??
for safety I can connect the limit switches to another input?
à moi les copeaux
gilles
gilles974
Postby cncdrive » Mon Oct 28, 2024 5:31 pm
Yes, its possible.
