UCCNC and W10 not starting
Postby tom2019 » Mon May 27, 2024 8:52 am
Was working for years, after some time not using it, I try to start the program, nothing happens, no errors.
Remove it, install it again, same bahaviour, no errors not starting.
Using the utility and can see my network or use devices.
Any idea of where is the problem?
tom2019
Re: UCCNC and W10 not starting
Postby cncdrive » Mon Jun 03, 2024 7:38 pm
And the utility tool says OK if you test the connection?
Postby tom2019 » Wed Jun 05, 2024 10:32 am
When I press Scan on the utility recognize the usb or the ethernet controller, whathever is connected.
Anyway here is not the problem, if not seen on the bus any controller program will start showing the demo controllers, but this never happens.
Is any way to trace or see what library or ther need to be installed or fails?
What microsoft runtime or other libraries are required?
tom2019
Postby mickecarlsson » Wed Jun 05, 2024 11:57 am
Check your Event log in Windows 10. Try to start UCCNC, then look in Event log for errors.
mickecarlsson
Postby tom2019 » Wed Jun 05, 2024 4:47 pm
Yes!!
Messages are in Spanish but it is clear more or less.
Error from UCCNC:
Aplicación: UCCNC.exe
Versión de Framework: v4.0.30319
Descripción: la aplicación solicitó la finalización del proceso a través de System.Environment.FailFast(mensaje de cadena).
Mensaje: Profiler detected
Pile:en System.Environment.FailFast(System.String)
Any solution for this?
tom2019
Postby tom2019 » Wed Jun 05, 2024 4:54 pm
Installing .NET 8.0 doesn´t solve the problem.
tom2019
Postby tom2019 » Wed Jun 05, 2024 7:44 pm
Installing .Net Framework 4.8.1 also no change.
tom2019
Postby cncdrive » Wed Jun 05, 2024 8:34 pm
UCCNC requires the .NET framework 4.0 and the Visual C++ redistributable 2008 package to run.
Postby tom2019 » Thu Jun 06, 2024 9:54 am
No results...
Trying to install .NET framework 4.0 and I get a message from installer saying I have a modern version so no need to install it.
Visual C++ redistributable 2008, I got a message saying reinstall or remove (so it is already installed), reinstall just in case, UCCNC still not starting.
tom2019
Postby cncdrive » Fri Jun 07, 2024 5:55 pm
The UCCNC requires nothing else, so I don't know why is it not running if both prerequirements are installed.
Try to repair the .net framework and the C++ redist package, maybe it has a problem.
Users browsing this forum: No registered users and 22 guests
